I just pick up an Rd 350 and was hopeing since this site rocks I could get some info from dudes who have one. First question I have is, what are you running for oil in your gear box? Also what type of brake fluid are you using?
thanks
thanks
you could get a workshop manual.
you*re gonna need one anyway to work on this beast
i don't own a rd but i can guess
dot 3 or 4 brake fluid like ever other bike. with disk brakes.
tranny fluid hopefully some one who knows more can tell you
Yeah I know I need to get a manual
prob says what kinf of fluid to use on the top of the master cyl.
I have a 75 rd350 use sea30 in trans. thats what the manual says. go to hvccycle.com for parts.
sorry sae 30 straight 30w engine oil.
There's better stuff than SAE30 these days, though you'd probly be fine with that. I use Motul Transoil in mine. I prefer it to regular motor oil cause it doesnt have the friction modifiers that modern motor oil does, which change the clutch performance. A lot of people like synthetic gear oil, too, like 85w or so.
Dot 3 or Dot 4 for the brake fluid.
Get a Clymer manual. It's better than the Haynes, though still not quite complete. USA2Strokers.com will help, too.
HVC sells tapered steering head bearings and brass + steel swingarm bushings that will stiffen it up somewhat.
Enjoy, RD's are fun as hell.
