1974 honda cb125 won't spark
So I just bought this bike and I was checking for spark and I found it to be weak so I cleaned the points and then it got better for a bit and then it died again. Now there is nothing at all. From what I read this could be a bad condensor maybe? Everything seems fine this bike is in pretty good shape I just don't know what it could be . what do you guys think?
thanks
Re: 1974 honda cb125 won't spark
Check the wire leading from the points to the condensor
It's in really nice shape and the connection looks good.
Battery charged? Manually open/close the points while checking spark.
With a test light check for voltage at pos coil, if yes put the light on neg coil and kick it over. Does it blink?
Right now there is no battery attached at all, I figured since it sparked without one at first I wouldnt need one to get spark?
My CL125 will NOT run without a charged battery.
It's funny that this happened to you when it did, because I did the exact same thing last week and haven't gotten around to solving the problem either.
Yup, my cb100 won't run without a battery either... i need to charge that damn thing.
i got engine parts for a cb125 Honda....if you need anything
tranny, stator, flywheel, cylinder, etc
But Leo, you've tainted them.
you*re right
they are conservative cb125 parts
should still work though
I wouldn't want to touch them.
