Mopeds in LA
I have a Puch Maxi-Luxe and the back tire popped Friday. Does anyone know where in LA I could get this fixed?
Thanks.
Re: Mopeds in LA
Crash Bandicoot /
Choke
Re: Mopeds in LA
CHOKE 4157 NORMAL AVE. LOS ANGELES, CA. 90029 323.662.4653
or do it yourself if you feel up to it.
http://www.mopedarmy.com/wiki/Tire_Change
And you can buy spare inner tubes at choke or online somewhere like http://www.treatland.tv/tires-n-tubes-s/121.htm
good luck !
Re: Mopeds in LA
Andrew Bowser /
Thanks!
Re: Mopeds in LA
all you need are some blunt tire spoons to prevent puncturing your new inner tube, it's just like changing a bike tire only there are nuts on the valve stem
Re: Mopeds in LA
Letting the tires warm up in the sun helps, as does soapy water. It also helps if you have the bead of the first side sit in the middle of the rim as you get the second side over the rim. Make sure to get the beads to seat once you inflate.
Re: Mopeds in LA
BryAn eurism /
Slime ftw, only leaves you walking if you hit a big one, till then, run every penny off the tread
