Puch Newport can't idle
my newport won't idle. im running the 70cc kstar kit with a 14 bing. it will run but when i let go of the clutch. it won't idle and it just dies. anyone tell me whats going on? thanks
Re: Puch Newport can't idle
Brian dieleman /
i know this should be in the performance section. i forgot that
ok you have a kit on there with a small carb ...did you jet it properly?what size jet you might be starving it from fuel ..advance the timing? you need 3 things to have a running bike compression,spark,and fuel my suggestion is to go over some other possible options while running a kit
Andrew's the expert! Listen to him!
