Re: Brakelight
don-ohio /
Hi,Brian! I just rebuilt the wheel bearings on my bike(it had the ball bearings with no retainer)and though I think the sealed bearings are o.k.,I think the open type will work fine if you replace the bearing races and use Molybdenum wheel bearing grease.If you replace them with sealed bearings ,you should also replace the main bolt and the spacing washers and grease them pretty well also but not enough where it could get into your brake drum.Remember too,that dirt is the enemy and water is the enemy,and you should get that hub clean of all grit before assembly.BYE!
  add a battery??Topic by: Richard Richard 05/27/01 01:59PM
  Re: add a battery??Re: Dan Dan 05/27/01 03:24PM
  Re: add a battery??Re: don-ohio don-ohio 05/27/01 04:07PM
  Re: add a battery??Re: Richard Richard 05/28/01 06:06PM
  Re: add a battery??Re: don-ohio don-ohio 05/29/01 02:42AM
  Re: add a battery??Re: Ron Brown Ron Brown 05/29/01 06:26PM
  Re: add a battery??Re: Richard Richard 05/29/01 10:01PM
  Re: add a battery??Re: Brian Brian 05/29/01 10:53PM
  Re: add a battery??Re: Richard Richard 05/30/01 09:08PM
  BrakelightRe: Brian Brian 05/30/01 10:03PM
  Re: BrakelightRe: don-ohio don-ohio 05/30/01 10:36PM
  Re: add a battery??Re: Ron Brown Ron Brown 05/31/01 11:22AM
  Re: add a battery??Re: Ron Brown Ron Brown 05/30/01 02:30PM
  Re: add a battery??Re: Ben Ben 05/28/01 10:37PM
  Re: add a battery??Re: Brian Brian 05/29/01 09:47PM
  Re: add a battery??Re: Ron Brown Ron Brown 05/30/01 12:00PM
  Re: add a battery??Re: don-ohio don-ohio 05/30/01 10:28PM
