Re: add a battery??
Brian /
Hi Richard,
This can be done. A zener diode of 6 volts is what you need. I will have to draw up a diagram of the circuit and send it to you. You use the brake light coil to charge your battery because that coil isn't doing anything most of the time while you are ridding. The way I have the system set up is that you switch between the battery or your regular system to power your headlight and tail light. During daylight ridding you are charging your battery and then at night if you are doing a lot of stop and go driving you can switch over to the battery to give you a constant headlight. Nothing more annoying then pulling up to a stop sign and having the lights go out on ya.
If it ain't broke, you're not trying hard enough.
Brian
Lamborn's Miniature Engines
  add a battery??Topic by: Richard Richard 05/27/01 01:59PM
  Re: add a battery??Re: Dan Dan 05/27/01 03:24PM
  Re: add a battery??Re: don-ohio don-ohio 05/27/01 04:07PM
  Re: add a battery??Re: Richard Richard 05/28/01 06:06PM
  Re: add a battery??Re: don-ohio don-ohio 05/29/01 02:42AM
  Re: add a battery??Re: Ron Brown Ron Brown 05/29/01 06:26PM
  Re: add a battery??Re: Richard Richard 05/29/01 10:01PM
  Re: add a battery??Re: Brian Brian 05/29/01 10:53PM
  Re: add a battery??Re: Richard Richard 05/30/01 09:08PM
  BrakelightRe: Brian Brian 05/30/01 10:03PM
  Re: BrakelightRe: don-ohio don-ohio 05/30/01 10:36PM
  Re: add a battery??Re: Ron Brown Ron Brown 05/31/01 11:22AM
  Re: add a battery??Re: Ron Brown Ron Brown 05/30/01 02:30PM
  Re: add a battery??Re: Ben Ben 05/28/01 10:37PM
  Re: add a battery??Re: Brian Brian 05/29/01 09:47PM
  Re: add a battery??Re: Ron Brown Ron Brown 05/30/01 12:00PM
  Re: add a battery??Re: don-ohio don-ohio 05/30/01 10:28PM
