Re: add a battery??
Dan /
Yes I am doing something like this right now. But I am hocking the lights up to a new seperate wirering system. I am now just using the coil to power the spark plug and not the lights as well. I have a 7 volt battery on the ped that powers only the lights. I found that if I used the motor to power my lights the engine would not run as good, and also when you slowed down the lights would dim. So I would say you should just use a new circut for the lighting system....
  add a battery??Topic by: Richard Richard 05/27/01 01:59PM
  Re: add a battery??Re: Dan Dan 05/27/01 03:24PM
  Re: add a battery??Re: don-ohio don-ohio 05/27/01 04:07PM
  Re: add a battery??Re: Richard Richard 05/28/01 06:06PM
  Re: add a battery??Re: don-ohio don-ohio 05/29/01 02:42AM
  Re: add a battery??Re: Ron Brown Ron Brown 05/29/01 06:26PM
  Re: add a battery??Re: Richard Richard 05/29/01 10:01PM
  Re: add a battery??Re: Brian Brian 05/29/01 10:53PM
  Re: add a battery??Re: Richard Richard 05/30/01 09:08PM
  BrakelightRe: Brian Brian 05/30/01 10:03PM
  Re: BrakelightRe: don-ohio don-ohio 05/30/01 10:36PM
  Re: add a battery??Re: Ron Brown Ron Brown 05/31/01 11:22AM
  Re: add a battery??Re: Ron Brown Ron Brown 05/30/01 02:30PM
  Re: add a battery??Re: Ben Ben 05/28/01 10:37PM
  Re: add a battery??Re: Brian Brian 05/29/01 09:47PM
  Re: add a battery??Re: Ron Brown Ron Brown 05/30/01 12:00PM
  Re: add a battery??Re: don-ohio don-ohio 05/30/01 10:28PM
