I need to find a replacement plug for a bosch w240t1. I would very much prefer a lower resistance platinum coer plug. Any ideas?
bosch plugs
Re: bosch plugs
Hi! You'll get more relief from resistance by replacing an old coil wire with a high performance one.Also,you've got to get the right heat range for your type of `ped and the fuel you're running.Plugs don't cost that much,so experiment a little with different heat ranges.BYE!
