Gas Tank Cleaning
Ron Brown /
These instructions were originally written for someone with a "Tank in frame" moped so if you have a removable tank, some operations are a lot easier.
I would stick with the acid only approach, as opposed to buying a Kreem kit which coats the tank. If your tank is excessively rusted, to the point where gas is seeping through the rusty spots, go to a motorcycle shop, buy a Kreem kit and follow the directions. The coating will seal small holes.
Pick up a gallon of Phosphoric acid and a bottle of "dry gas".
Most buisinesses using large stainless steel vessels use Phosphoric acid. Dairy farmers, dairy products, brewerys etc. Posibly you could call one, or just stop by, it is cheap and they may just give you some. I have also heard that it is sold in Meijers pool section so I suppose other pool supply stores would have it. "Dry gas" is available at auto parts and gas stations for removing water from your fuel system.
Whem you use it, you are going to have to figure out how to get it back out of the tank safely. Typically, with a removable tank, you can just duct tape over the holes and dump it by removing the tape. You must remove the petcock and removing the gas cap is a good idea as it has a vent hole which can leak acid.
If the petcock scews into a threaded hole in the tank, maybe you can find a brass nipple that will fit the thread and allow you to drain the acid safely. If you have no choice but tape, remember that a running hose is your best defense against disaster.
For all of the following, keep a garden hose available and turned on. Wear old clothes, there is a good chance they will become religious, as in holey. Work outside, away from anything which could get splashed. When rinsing, use a lot of low pressure water, high pressure will send acid to places where it may do damage before you find it.
Dilute some acid in a plastic container and test it with a piece of rusty steel. You want it to remove the rust in about ten minutes but you are not looking for a violent reaction.
Remove the petcock and plug the hole with something appropriate, good duct tape usually works. Remove the gas cap if possible, if not, cover the hole with saran wrap before closing the cap to keep the vents from filling with acid.
Pour enough diluted acid in the tank to almost fill it. Seal the filler with tape or the cap/saran wrap and slosh the acid so that it is cleaning the top side of the tank. Just rocking the bike will do this. Keep an eye open for leaks and rinse off any acid you see immediately with a slow hose. Keep sloshing every minute or so until your time is up as determined by the test above, then slosh and wait five minutes more.
I am not sure how you are going to drain the tank but if you have not figured out a drain tube, lean the ped so most of the acid will fall straight to the ground and keep a sready flow of water on the hose to rinse any parts of the ped which get splashed.
Btw, letting the acid run into the ground in your yard is not an ecological disaster. Many plants prefer acidic soil. Don't let your pets get near it, dilute it a lot and don't dump it all in one place, especially not at the base of a tree.
Check the inside of the tank to make sure you do not need another application.
Using a rinse and slosh tecnique, get rid of all the acid in the gas tank then dry off the ped. If you have an air line, blow out the tank. If not, dry it as well as you can with rags, paper towels, hair dryer etc. Then replace the petcock and pour a bottle of "dry gas" into the tank and close the lid. Slosh this around for a few minutes to mix with any remaining water trapped in the tank seams, then drain it out.
Add gas and ped away.
Fred
Ron Brown /
Fred,
Feel free to edit/add this to your "How to fix your Moped". That way I will not have to keep moving it up and people can sue you for all the holes burned in thier clothes. :-)
Ron
Re: Gas Tank Cleaning
The stuff we have a work called Lime-A-Way is almost entirely phosphoric acid. You should be able to find it at a home-depot or wal-mart or possibly some supermarkets. It comes pretty concentrated and works great. It's also only a few bucks per gallon and pretty easy to find. Another brand that's supposed to do the same thing is C-L-R. I've never tried CLR, but I assume it's also mostly phosphoric acid. You might also try a chemical supply house and get some of the acid anhydride (P2 O5). That way, you could fill the tank with water and add the anhydride to the tank to make phosphoric acid (less chance of spilling it on something).
There's stuff called "Naval Jelly," it's pretty potent phosphoric acid, but not to the point that it'll burn you if you get some on your hands (at least not right away, don't dunk your hands in the stuff thinking it's safe). It's normally about the consistency of yogurt, but there's a sprayable liquid form too. worked great on my spree tank.
I just baked my tank to get the water out. I turned the stove to just above 200 degrees and let it sit for fifteen minutes. the fresh metal will rust quickly this way, though. Nothing serious, though.
