Re: stripped bolt heads
Jim C. /
As long as they are not hardened screws, I usually will drill the head off using a bit just slightly bigger than the screw shaft. Drill just deep enough to get the head to fall off. After you remove the cover, the remaining portion of the screw sticks out, leaving a great place to grab it with Vice-Grips.
Jim C.
  stripped bolt headsTopic by: spartovi spartovi 05/25/01 11:43PM
  Re: stripped bolt headsRe: Michael Michael 05/26/01 02:08AM
  Re: stripped bolt headsRe: spartovi spartovi 05/26/01 05:31AM
  Re: stripped bolt headsRe: Jim C. Jim C. 05/26/01 11:56AM
  Re: stripped bolt headsRe: Rick Rick 05/27/01 12:42AM
  Re: stripped bolt headsRe: Ken Ken 05/27/01 03:55PM
  Re: stripped bolt headsRe: Heath Heath 05/28/01 01:04AM
