Re: stripped bolt heads
Michael /
what kind of screws? if they're phillips you might try an impact driver (a screwdriver where you slam on it with a hammer causing it to both apply a lot of pressure and turn the screw at the same time). If you can get a pair of vice grips around it you might try 'hot-wrenching' it (use a propane torch on it to get it hot, then put the vice grips on and turn it). if you cant get any of these to work you can try and drill it out.. but that should be a last resort i think.
  stripped bolt headsTopic by: spartovi spartovi 05/25/01 11:43PM
  Re: stripped bolt headsRe: Michael Michael 05/26/01 02:08AM
  Re: stripped bolt headsRe: spartovi spartovi 05/26/01 05:31AM
  Re: stripped bolt headsRe: Jim C. Jim C. 05/26/01 11:56AM
  Re: stripped bolt headsRe: Rick Rick 05/27/01 12:42AM
  Re: stripped bolt headsRe: Ken Ken 05/27/01 03:55PM
  Re: stripped bolt headsRe: Heath Heath 05/28/01 01:04AM
