Puch Maxi Wiring
I have a Puch Maxi 1980 1.5hp. The wiring diagrams on the Internet show 5 wires from the magneto to the moped. This moped has an additional 6th wire
color-coded ( BLUE/BLACK Stripe. What's the purpose of this wire? The wire is
bundled with the headlamp/on-off/horn/ etc. Thanks in advance.
Re: Puch Maxi Wiring
Tony,
I got a Haynes Puch manual. According to the manual.
Grey - Running tail light
Green/Black - Ground/Ignition Coil
Green - Brake light switch
Yellow - (#56) Terminal on Lighting switch/horn switch
Blue - Ignition Coil
Blue/Black - Horn & (H) Terminal on Lighting switch/horn switch
Hope this helps
