Peggy,
In Michigan, if gas has alcohol added, it must be posted on the pump. You might check to see if this is true in your state.
As for it being bad for the ped, alcohol is more corosive that gas and can attack certain plastict that gas will not, but most modern engines are built to run on 10% alcohol with no problem.
Ron
