Re: Which Gas is the Best Gas
Droopy Drawls /
Higher octane gas has more double hydrogen bonds and therefore resists combustion better. It is only used for high performance engines with higher compression. Since the fuel will not auto-combust at high pressures, you can compress the fuel mixture more, which burns more efficiently, making a larger explosion and creating more power. You don't have enough compression in your engine to make use of this effect. Actually, it has a negative effect since it will retard the ignition timing. I AM WATCHING YOU!
  Which Gas is the Best GasTopic by: Kyle Witten Kyle Witten 05/23/01 02:54AM
  Re: Which Gas is the Best GasRe: Chris Robertson Chris Robertson 05/23/01 10:20AM
  Re: Which Gas is the Best GasRe: Droopy Drawls Droopy Drawls 05/23/01 02:28PM
  Re: Theyr'e all the same, kinda...Re: Jim C. Jim C. 05/24/01 12:05AM
  Re: Theyr'e all the same, kinda...Re: Doug D. Doug D. 05/24/01 12:18AM
  Re: Try bothRe: Andy Andy 05/24/01 03:13AM
  Re: Which Gas is the Best GasRe: Peggy Peggy 05/25/01 11:39AM
  Re: Which Gas is the Best GasRe: Ron Brown Ron Brown 05/25/01 12:43PM
  Re: Which Gas is the Best GasRe: don-ohio don-ohio 05/26/01 04:04PM
