Re: Poloni 75cc problem
Organ Robbin' /
if the jet was too big...on a cold start it would fire right up as if it were being choked. I understand your logic Nash but as I stated unless you PROPERLY check everything else, you cant be sure. I start with getting an exact timing setup with marks on the flywheel using a spark plug micrometer set to about 1.2-1.4mm BTDC then make sure you've got good compression with a spark plug compression gauge and a drill. Next start where polini reccomends and go up jet sizes from there. Otherwise you might as well be holding a knife and trying to take a stab in the dark.
  Poloni 75cc problemTopic by: Aron Aron 01/20/11 06:10PM
  Re: Poloni 75cc problemRe: Organ Robbin' Organ Robbin' 01/20/11 06:13PM
  Re: Poloni 75cc problemRe: Aron Aron 01/20/11 06:17PM
  Re: Poloni 75cc problemRe: §ćŗάτçλmªřċ • §ćŗάτçλmªřċ • 01/20/11 06:33PM
  Re: Poloni 75cc problemRe: Aron Aron 01/20/11 06:40PM
  Re: Poloni 75cc problemRe: Perfekt Timing Angel Perfekt Timing Angel 01/20/11 06:52PM
  Re: Poloni 75cc problemRe: x d x d 01/20/11 06:53PM
  Re: Poloni 75cc problemRe: Aron Aron 01/20/11 06:58PM
  Re: Poloni 75cc problemRe: Aron Aron 01/20/11 07:06PM
  Re: Poloni 75cc problemRe: Aron Aron 01/20/11 07:13PM
  Re: Poloni 75cc problemRe: x d x d 01/20/11 07:14PM
  Re: Poloni 75cc problemRe: x d x d 01/20/11 07:19PM
  Re: Poloni 75cc problemRe: Aron Aron 01/20/11 07:27PM
  Re: Poloni 75cc problemRe: Aron Aron 01/20/11 07:32PM
  Re: Poloni 75cc problemRe: Aron Aron 01/20/11 07:35PM
  Re: Poloni 75cc problemRe: Serious Business Serious Business 01/20/11 07:51PM
  Re: Poloni 75cc problemRe: Serious Business Serious Business 01/20/11 07:53PM
  Re: Poloni 75cc problemRe: Aron Aron 01/20/11 08:12PM
  Re: Poloni 75cc problemRe: Serious Business Serious Business 01/20/11 08:16PM
  Re: Poloni 75cc problemRe: Cpt. F. Cpt. F. 01/20/11 08:36PM
  Re: Poloni 75cc problemRe: Aron Aron 01/20/11 08:37PM
  Re: Poloni 75cc problemRe: Cpt. F. Cpt. F. 01/20/11 08:39PM
  Re: Poloni 75cc problemRe: Eoban Eoban 01/20/11 08:41PM
  Re: Poloni 75cc problemRe: Serious Business Serious Business 01/20/11 08:50PM
  Re: Poloni 75cc problemRe: Aron Aron 01/20/11 08:56PM
  Re: Poloni 75cc problemRe: Peter C Peter C 01/20/11 09:04PM
  Re: Poloni 75cc problemRe: Aron Aron 01/20/11 09:04PM
  Re: Poloni 75cc problemRe: Responsible Jon Responsible Jon 01/20/11 09:15PM
  Re: Poloni 75cc problemRe: Serious Business Serious Business 01/20/11 09:20PM
  Re: Poloni 75cc problemRe: x d x d 01/20/11 09:32PM
  Re: Poloni 75cc problemRe: Toledo Riot Toledo Riot 01/20/11 10:03PM
  Re: Poloni 75cc problemRe: larry larry 01/20/11 10:48PM
  Re: Poloni 75cc problemRe: Aron Aron 01/21/11 01:03PM
  Re: Poloni 75cc problemRe: Organ Robbin' Organ Robbin' 01/21/11 01:19PM
  Re: Poloni 75cc problemRe: Aron Aron 01/21/11 01:28PM
  Re: Poloni 75cc problemRe: Organ Robbin' Organ Robbin' 01/21/11 02:07PM
  Re: Poloni 75cc problemRe: Silverfox Sullivan Silverfox Sullivan 01/21/11 02:14PM
  Re: Poloni 75cc problemRe: Cpt. F. Cpt. F. 01/21/11 02:16PM
  Re: Poloni 75cc problemRe: Aron Aron 01/21/11 02:21PM
  Re: Poloni 75cc problemRe: Organ Robbin' Organ Robbin' 01/21/11 02:48PM
  Re: Poloni 75cc problemRe: Aron Aron 01/21/11 02:52PM
  Re: Poloni 75cc problemRe: truckerick truckerick 01/21/11 05:31PM
  Re: Poloni 75cc problemRe: Nash . Nash . 01/21/11 05:40PM
  Re: Poloni 75cc problemRe: Nash . Nash . 01/21/11 05:48PM
  Re: Poloni 75cc problemRe: Organ Robbin' Organ Robbin' 01/21/11 05:49PM
  Re: Poloni 75cc problemRe: Nash . Nash . 01/21/11 05:51PM
  Re: Poloni 75cc problemRe: Aron Aron 01/21/11 10:47PM
  Re: Poloni 75cc problemRe: Perfekt Timing Angel Perfekt Timing Angel 01/21/11 11:15PM
  Re: Poloni 75cc problemRe: Aron Aron 01/21/11 11:54PM
  Re: Poloni 75cc problemRe: Perfekt Timing Angel Perfekt Timing Angel 01/22/11 12:04AM
  Re: Poloni 75cc problemRe: Aron Aron 01/22/11 12:11AM
  Re: Poloni 75cc problemRe: Aron Aron 01/22/11 12:18AM
  Re: Poloni 75cc problemRe: Responsible Jon Responsible Jon 01/22/11 10:48AM
  Re: Poloni 75cc problemRe: Aron Aron 01/22/11 01:52PM
  Re: Poloni 75cc problemRe: mike mike 01/22/11 04:42PM
  Re: Poloni 75cc problemRe: Nash . Nash . 01/22/11 08:23PM
  Re: Poloni 75cc problemRe: Aron Aron 01/22/11 08:35PM
  Re: Poloni 75cc problemRe: Nash . Nash . 01/22/11 08:47PM
  Re: Poloni 75cc problemRe: Aron Aron 01/22/11 09:01PM
  Re: Poloni 75cc problemRe: Aron Aron 01/24/11 12:27PM
  Re: Poloni 75cc problemRe: Cpt. F. Cpt. F. 01/24/11 12:45PM
  Re: Poloni 75cc problemRe: Aron Aron 01/24/11 01:03PM
  Re: Poloni 75cc problemRe: Cpt. F. Cpt. F. 01/24/11 01:10PM
  Re: Poloni 75cc problemRe: Aron Aron 01/24/11 01:22PM
  Re: Poloni 75cc problemRe: DWAYNE DWAYNE 01/24/11 01:29PM
  Re: Poloni 75cc problemRe: Mo Peds Mo Peds 01/24/11 01:31PM
  Poloni 75cc problemRe: Chris HnRz Chris HnRz 01/24/11 01:33PM
  Re: Poloni 75cc problemRe: Perfekt Timing Angel Perfekt Timing Angel 01/24/11 02:01PM
  Re: Poloni 75cc problemRe: DWAYNE DWAYNE 01/24/11 02:06PM
  Re: Poloni 75cc problemRe: DWAYNE DWAYNE 01/24/11 02:10PM
  Re: Poloni 75cc problemRe: Andrew Squiggman Andrew Squiggman 01/24/11 04:01PM
  Re: Poloni 75cc problemRe: Aron Aron 01/24/11 06:44PM
  Re: Poloni 75cc problemRe: Aron Aron 01/24/11 06:45PM
  Re: Poloni 75cc problemRe: Aron Aron 01/24/11 07:49PM
  Re: Poloni 75cc problemRe: Aron Aron 01/24/11 08:51PM
  Re: Poloni 75cc problemRe: Perfekt Timing Angel Perfekt Timing Angel 01/24/11 09:49PM
  Re: Poloni 75cc problemRe: Perfekt Timing Angel Perfekt Timing Angel 01/24/11 09:55PM
  Re: Poloni 75cc problemRe: Aron Aron 01/24/11 10:11PM
  Re: Poloni 75cc problemRe: Aron Aron 01/24/11 10:16PM
  Re: Poloni 75cc problemRe: Aron Aron 01/30/11 02:40PM
  Re: Poloni 75cc problemRe: Mo Peds Mo Peds 01/30/11 03:13PM
  Re: Poloni 75cc problemRe: Aron Aron 01/30/11 03:26PM
  Re: Poloni 75cc problemRe: Mo Peds Mo Peds 01/30/11 03:30PM
  Re: Poloni 75cc problemRe: Aron Aron 01/30/11 11:29PM
  Re: Poloni 75cc problemRe: Aron Aron 01/31/11 08:09PM
  Re: Poloni 75cc problemRe: Responsible Jon Responsible Jon 01/31/11 08:39PM
  Re: Poloni 75cc problemRe: Aron Aron 01/31/11 08:40PM
  Re: Poloni 75cc problemRe: Cpt. F. Cpt. F. 01/31/11 08:48PM
  Re: Poloni 75cc problemRe: birddawg birddawg 01/31/11 10:38PM
  Re: Poloni 75cc problemRe: Perfekt Timing Angel Perfekt Timing Angel 02/01/11 02:05AM
  Re: Poloni 75cc problemRe: Cpt. F. Cpt. F. 02/01/11 11:16AM
  Re: Poloni 75cc problemRe: Responsible Jon Responsible Jon 02/01/11 11:21AM
  Re: Poloni 75cc problemRe: Mo Peds Mo Peds 02/01/11 11:22AM
  Re: Poloni 75cc problemRe: Aron Aron 02/01/11 01:27PM
  Re: Poloni 75cc problemRe: Aron Aron 02/01/11 07:14PM
  Re: Poloni 75cc problemRe: Aron Aron 02/05/11 03:24AM
  Re: Poloni 75cc problemRe: Mo Peds Mo Peds 02/05/11 05:29AM
  Re: Poloni 75cc problemRe: Aron Aron 02/05/11 01:24PM
  Re: Poloni 75cc problemRe: Mo Peds Mo Peds 02/05/11 01:34PM
  Re: Poloni 75cc problemRe: Aron Aron 02/05/11 11:17PM
  Re: Poloni 75cc problemRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 02/06/11 12:04AM
  Re: Poloni 75cc problemRe: Aron Aron 02/06/11 08:57PM
  Re: Poloni 75cc problemRe: Mo Peds Mo Peds 02/06/11 09:09PM
  Re: Poloni 75cc problemRe: Aron Aron 02/06/11 09:42PM
