Re: Poloni 75cc problem
Responsible Jon /
Aron, ironically, you also are acting like a tough guy. Just let it go.
You need to gather more data, and the solution will present itself.
Verify
Piston orientation (arrow down)
Spark. Hold the plug on the cylinder and try to start the motor, does it spark? Check your timing, make sure your point gap is correct (see the wiki)
Fuel in the tank with a good flow from the hose
Fuel in the bowl of the carburetor
Is the head installed with the head gasket and evenly tightened down?
Is the base gasket still intact? How are your case seals?
  Poloni 75cc problemTopic by: Aron Aron 01/20/11 06:10PM
  Re: Poloni 75cc problemRe: Organ Robbin' Organ Robbin' 01/20/11 06:13PM
  Re: Poloni 75cc problemRe: Aron Aron 01/20/11 06:17PM
  Re: Poloni 75cc problemRe: §ćŗάτçλmªřċ • §ćŗάτçλmªřċ • 01/20/11 06:33PM
  Re: Poloni 75cc problemRe: Aron Aron 01/20/11 06:40PM
  Re: Poloni 75cc problemRe: Perfekt Timing Angel Perfekt Timing Angel 01/20/11 06:52PM
  Re: Poloni 75cc problemRe: x d x d 01/20/11 06:53PM
  Re: Poloni 75cc problemRe: Aron Aron 01/20/11 06:58PM
  Re: Poloni 75cc problemRe: Aron Aron 01/20/11 07:06PM
  Re: Poloni 75cc problemRe: Aron Aron 01/20/11 07:13PM
  Re: Poloni 75cc problemRe: x d x d 01/20/11 07:14PM
  Re: Poloni 75cc problemRe: x d x d 01/20/11 07:19PM
  Re: Poloni 75cc problemRe: Aron Aron 01/20/11 07:27PM
  Re: Poloni 75cc problemRe: Aron Aron 01/20/11 07:32PM
  Re: Poloni 75cc problemRe: Aron Aron 01/20/11 07:35PM
  Re: Poloni 75cc problemRe: Serious Business Serious Business 01/20/11 07:51PM
  Re: Poloni 75cc problemRe: Serious Business Serious Business 01/20/11 07:53PM
  Re: Poloni 75cc problemRe: Aron Aron 01/20/11 08:12PM
  Re: Poloni 75cc problemRe: Serious Business Serious Business 01/20/11 08:16PM
  Re: Poloni 75cc problemRe: Cpt. F. Cpt. F. 01/20/11 08:36PM
  Re: Poloni 75cc problemRe: Aron Aron 01/20/11 08:37PM
  Re: Poloni 75cc problemRe: Cpt. F. Cpt. F. 01/20/11 08:39PM
  Re: Poloni 75cc problemRe: Eoban Eoban 01/20/11 08:41PM
  Re: Poloni 75cc problemRe: Serious Business Serious Business 01/20/11 08:50PM
  Re: Poloni 75cc problemRe: Aron Aron 01/20/11 08:56PM
  Re: Poloni 75cc problemRe: Peter C Peter C 01/20/11 09:04PM
  Re: Poloni 75cc problemRe: Aron Aron 01/20/11 09:04PM
  Re: Poloni 75cc problemRe: Responsible Jon Responsible Jon 01/20/11 09:15PM
  Re: Poloni 75cc problemRe: Serious Business Serious Business 01/20/11 09:20PM
  Re: Poloni 75cc problemRe: x d x d 01/20/11 09:32PM
  Re: Poloni 75cc problemRe: Toledo Riot Toledo Riot 01/20/11 10:03PM
  Re: Poloni 75cc problemRe: larry larry 01/20/11 10:48PM
  Re: Poloni 75cc problemRe: Aron Aron 01/21/11 01:03PM
  Re: Poloni 75cc problemRe: Organ Robbin' Organ Robbin' 01/21/11 01:19PM
  Re: Poloni 75cc problemRe: Aron Aron 01/21/11 01:28PM
  Re: Poloni 75cc problemRe: Organ Robbin' Organ Robbin' 01/21/11 02:07PM
  Re: Poloni 75cc problemRe: Silverfox Sullivan Silverfox Sullivan 01/21/11 02:14PM
  Re: Poloni 75cc problemRe: Cpt. F. Cpt. F. 01/21/11 02:16PM
  Re: Poloni 75cc problemRe: Aron Aron 01/21/11 02:21PM
  Re: Poloni 75cc problemRe: Organ Robbin' Organ Robbin' 01/21/11 02:48PM
  Re: Poloni 75cc problemRe: Aron Aron 01/21/11 02:52PM
  Re: Poloni 75cc problemRe: truckerick truckerick 01/21/11 05:31PM
  Re: Poloni 75cc problemRe: Nash . Nash . 01/21/11 05:40PM
  Re: Poloni 75cc problemRe: Nash . Nash . 01/21/11 05:48PM
  Re: Poloni 75cc problemRe: Organ Robbin' Organ Robbin' 01/21/11 05:49PM
  Re: Poloni 75cc problemRe: Nash . Nash . 01/21/11 05:51PM
  Re: Poloni 75cc problemRe: Aron Aron 01/21/11 10:47PM
  Re: Poloni 75cc problemRe: Perfekt Timing Angel Perfekt Timing Angel 01/21/11 11:15PM
  Re: Poloni 75cc problemRe: Aron Aron 01/21/11 11:54PM
  Re: Poloni 75cc problemRe: Perfekt Timing Angel Perfekt Timing Angel 01/22/11 12:04AM
  Re: Poloni 75cc problemRe: Aron Aron 01/22/11 12:11AM
  Re: Poloni 75cc problemRe: Aron Aron 01/22/11 12:18AM
  Re: Poloni 75cc problemRe: Responsible Jon Responsible Jon 01/22/11 10:48AM
  Re: Poloni 75cc problemRe: Aron Aron 01/22/11 01:52PM
  Re: Poloni 75cc problemRe: mike mike 01/22/11 04:42PM
  Re: Poloni 75cc problemRe: Nash . Nash . 01/22/11 08:23PM
  Re: Poloni 75cc problemRe: Aron Aron 01/22/11 08:35PM
  Re: Poloni 75cc problemRe: Nash . Nash . 01/22/11 08:47PM
  Re: Poloni 75cc problemRe: Aron Aron 01/22/11 09:01PM
  Re: Poloni 75cc problemRe: Aron Aron 01/24/11 12:27PM
  Re: Poloni 75cc problemRe: Cpt. F. Cpt. F. 01/24/11 12:45PM
  Re: Poloni 75cc problemRe: Aron Aron 01/24/11 01:03PM
  Re: Poloni 75cc problemRe: Cpt. F. Cpt. F. 01/24/11 01:10PM
  Re: Poloni 75cc problemRe: Aron Aron 01/24/11 01:22PM
  Re: Poloni 75cc problemRe: DWAYNE DWAYNE 01/24/11 01:29PM
  Re: Poloni 75cc problemRe: Mo Peds Mo Peds 01/24/11 01:31PM
  Poloni 75cc problemRe: Chris HnRz Chris HnRz 01/24/11 01:33PM
  Re: Poloni 75cc problemRe: Perfekt Timing Angel Perfekt Timing Angel 01/24/11 02:01PM
  Re: Poloni 75cc problemRe: DWAYNE DWAYNE 01/24/11 02:06PM
  Re: Poloni 75cc problemRe: DWAYNE DWAYNE 01/24/11 02:10PM
  Re: Poloni 75cc problemRe: Andrew Squiggman Andrew Squiggman 01/24/11 04:01PM
  Re: Poloni 75cc problemRe: Aron Aron 01/24/11 06:44PM
  Re: Poloni 75cc problemRe: Aron Aron 01/24/11 06:45PM
  Re: Poloni 75cc problemRe: Aron Aron 01/24/11 07:49PM
  Re: Poloni 75cc problemRe: Aron Aron 01/24/11 08:51PM
  Re: Poloni 75cc problemRe: Perfekt Timing Angel Perfekt Timing Angel 01/24/11 09:49PM
  Re: Poloni 75cc problemRe: Perfekt Timing Angel Perfekt Timing Angel 01/24/11 09:55PM
  Re: Poloni 75cc problemRe: Aron Aron 01/24/11 10:11PM
  Re: Poloni 75cc problemRe: Aron Aron 01/24/11 10:16PM
  Re: Poloni 75cc problemRe: Aron Aron 01/30/11 02:40PM
  Re: Poloni 75cc problemRe: Mo Peds Mo Peds 01/30/11 03:13PM
  Re: Poloni 75cc problemRe: Aron Aron 01/30/11 03:26PM
  Re: Poloni 75cc problemRe: Mo Peds Mo Peds 01/30/11 03:30PM
  Re: Poloni 75cc problemRe: Aron Aron 01/30/11 11:29PM
  Re: Poloni 75cc problemRe: Aron Aron 01/31/11 08:09PM
  Re: Poloni 75cc problemRe: Responsible Jon Responsible Jon 01/31/11 08:39PM
  Re: Poloni 75cc problemRe: Aron Aron 01/31/11 08:40PM
  Re: Poloni 75cc problemRe: Cpt. F. Cpt. F. 01/31/11 08:48PM
  Re: Poloni 75cc problemRe: birddawg birddawg 01/31/11 10:38PM
  Re: Poloni 75cc problemRe: Perfekt Timing Angel Perfekt Timing Angel 02/01/11 02:05AM
  Re: Poloni 75cc problemRe: Cpt. F. Cpt. F. 02/01/11 11:16AM
  Re: Poloni 75cc problemRe: Responsible Jon Responsible Jon 02/01/11 11:21AM
  Re: Poloni 75cc problemRe: Mo Peds Mo Peds 02/01/11 11:22AM
  Re: Poloni 75cc problemRe: Aron Aron 02/01/11 01:27PM
  Re: Poloni 75cc problemRe: Aron Aron 02/01/11 07:14PM
  Re: Poloni 75cc problemRe: Aron Aron 02/05/11 03:24AM
  Re: Poloni 75cc problemRe: Mo Peds Mo Peds 02/05/11 05:29AM
  Re: Poloni 75cc problemRe: Aron Aron 02/05/11 01:24PM
  Re: Poloni 75cc problemRe: Mo Peds Mo Peds 02/05/11 01:34PM
  Re: Poloni 75cc problemRe: Aron Aron 02/05/11 11:17PM
  Re: Poloni 75cc problemRe: #CrazyWayne™ rocks. #CrazyWayne #CrazyWayne™ rocks. #CrazyWayne 02/06/11 12:04AM
  Re: Poloni 75cc problemRe: Aron Aron 02/06/11 08:57PM
  Re: Poloni 75cc problemRe: Mo Peds Mo Peds 02/06/11 09:09PM
  Re: Poloni 75cc problemRe: Aron Aron 02/06/11 09:42PM
