This is going to be the first time I'm going to change transmission fluid. Approx. how much fluid shoud I measure?
transmission fluid question
fill-er-up.
": This is going to be the first time I'm going to change transmission fluid. Approx. how much fluid shoud I measure?<p>I don't know the exact capacity, but you should fill it until the fluid runs out the fill hole, with the moped sitting on level ground. (approximately 1 pint or so.)"
Thanx
": : This is going to be the first time I'm going to change transmission fluid. Approx. how much fluid shoud I measure?<p>: I don't know the exact capacity, but you should fill it until the fluid runs out the fill hole, with the moped sitting on level ground. (approximately 1 pint or so.)<p>"
