2 speed... 70cc kit
whats up folks,
I just got a 70cc reed valve kit and I'm not sure if I should put it on my 2 speed puch (ZA50) or my Newport. My main concern is wearing out the first gear clutch. Any thoughts?
Happy Pedding to all
Tom.
Re: 2 speed... 70cc kit
the clutch will be just fine.........
the pucks is the thing to wonder about.
my virgin 30yr old za50 has held up just fine with kit/pipe/carb added on.
You will get two sides..
One- replace your pucks..put it on and rip
Two- Total tear down..replace all bearings and seals..get the new fandangled 1st and 2nd gear clutch..case match..put it on and rip.
Your choice man.
za50 are sooo fun and just a little bit of extra work. you should replace your shift dampeners at the very least and bearings and seals is a good idea too. no need to replace your clutches if they look fine. it might seem daunting at first but it is actually quite easy once you get into it.
