Re: How To Fix Your Moped
don-ohio /
Hi,Larry! It might help if you start a new post with this question.Just click `new topic' at the top.As far as an underwater `ped goes,I'm really shocked at the amount of moped thieving I hear about on this forum.Now I know why they need an ARMY! I'd say your chances of having a ruined condenser and maybe coil,(definitely replace the spark plug wire) are pretty good.Also,change out the gearbox oil and totally lube the cylinder and piston before you fire it up.Even your ignition switch and wiring in general will need checked also.(Headlight,Taillight,etc.)Not to mention what may have happened to your fuel system!BYE!
  How To Fix Your MopedTopic by: Fred Fred 05/20/01 12:05AM
  Re: How To Fix Your MopedRe: Wayne Broderick Wayne Broderick 05/20/01 08:42PM
  Re: How To Fix Your MopedRe: larry larry 06/25/01 10:17PM
  Re: How To Fix Your MopedRe: don-ohio don-ohio 06/25/01 11:33PM
