Re: Fred was right again
Ron Brown /
Don,
I took the liberty of pasting your email in here ahead of my response because it confused me and maybe someone will enjoy your puzzle.
>Hi! Now Ron,get real! Call any moped repair shop and
>ask how many failed condensers show up.I'm sure though
>rare, as Fred says,there are many replaced each year
>and anybody knows that anything mechanical can fail at
>any time.
My confusion here is that in my previous post, I wondered if your mechanic would still think my coil was bad, even though my condensor read 5 K ohms, proving that it was bad. I don't recall ever mentioning that condensors rarely fail. In fact, even though I have not seen too many failures, I would assume that they are failure prone, or why would points and condensor normally come together in a tune up kit?
>Let me give you an example of a
>rarity.Problem yesterday: Moped doesn't start.Spark
>plug has very weak spark.The diagnosis normally would
>be pretty easy,right? Not in this case,at least not
>for me.Care to take a stab at it? I solved it
>yesterday by removing the spark plug.The clue is
>`noise',so you don't think I am making this up.Another
>hint is : these don't fail very often either. BYE!
Without the clue, I would have to suspect anything and everything in the ignition circuit, from the magnets in the flywheel to the plug. Given that the clue is "noise", I have to guess you mean RF noise and the plug suppressor cap was bad. I am not sure how you solved it by removing the spark plug, my ped won't run worth a hoot without one.
Ron
  Motobecane problemTopic by: Ron Brown Ron Brown 05/18/01 11:57AM
  Re: Motobecane problemRe: don-ohio don-ohio 05/18/01 10:15PM
  Re: Motobecane problemRe: mike mike 05/18/01 10:42PM
  Re: Motobecane problemRe: Ron Brown Ron Brown 05/19/01 10:22AM
  Re: Motobecane problemRe: Ron Brown Ron Brown 05/19/01 10:18AM
  Re: Motobecane problemRe: Ron Brown Ron Brown 05/19/01 10:53AM
  Re: Motobecane problemRe: Ron Brown Ron Brown 05/19/01 01:20PM
  EurekaRe: Ron Brown Ron Brown 05/19/01 06:26PM
  Re: EurekaRe: don-ohio don-ohio 05/19/01 10:15PM
  Fred was right againRe: Ron Brown Ron Brown 05/20/01 01:31PM
  Re: Fred was right againRe: don-ohio don-ohio 05/21/01 02:20PM
  Re: Fred was right againRe: Ron Brown Ron Brown 05/21/01 02:41PM
  Re: Fred was right againRe: don-ohio don-ohio 05/22/01 02:47PM
  Re: Fred was right againRe: Ron Brown Ron Brown 05/22/01 03:25PM
  Re: Fred was right againRe: don-ohio don-ohio 05/25/01 08:38AM
  Re: Fred was right againRe: Ron Brown Ron Brown 05/25/01 12:15PM
  Re: Fred was right againRe: don-ohio don-ohio 05/26/01 05:09PM
  Re: Motobecane problemRe: don-ohio don-ohio 05/25/01 08:01PM
