been thinking i need a piston stop but it kinda looks like you could easily fuck up a piston crown with one.so who here has wished they did the rope trick instead?
use a rope that will barely fit in the sparkplug whole, and something thats real squishy, no frayed ends. youll get it hung up on the ports or rings if you have too little diameter rope. ive heard of crazy shit like bent con rods, shattered pistons from piston stops.
I use a plastic tipped piston stop and have never had trouble. I have not had good luck with rope. Last time I used it, the rope got squeezed and got stuck in the piston ring. Maybe I was not using thick enough rope, but I like piston stops.
dont forget certain things can be done with a strap wrench instead, like flywheel removal.
At pittsburgh Chad Burke had some really nice nylon-tipped piston stops, so maybe check quarterkick. I've always used rope with no problem, though
i've used rope a few times. And i hate it. Very much so. Yes it gets caught.
Especially if you are taking off your clutch (repeatedly). Why spend all that time screwing around with your top end trying to lock it in place just to remove one nut on the clutch.
It's worth it, buy it with your next set of tires or whatever.
I like the rope trick. I have used a lot of things like a shoe string, cotton rope, or whatever I can find and never had a problem.
I have a piece of bungee cord that works really well.
I use a length of vacuum hose. But really, if you're bending rods and shattering pistons, you must be using an impact or something.
Before I knew the rope trick I would position the piston above the exhaust port, fill the cylinder with oil and screw the spark plug in. I like the rubber hose and bungee ideas
yeah, the bungee coils itself around the cylinder and if its fat you only need a few inches, plus its nice and squishy.
Chain vice grips work well.
But with an impact gun, you shouldn't need anything to stop the piston. Works queeeek.
a cordless impact is the single greatest tool in moped repair.
I just used some yellow rope today to get in there. It worked like a charm.
Rob I would tend to agree with you.
But, Plug wrench wins.
nasty.. metal piston stops work fine.. aslong as you set the piston on the stop before you do any wrenching.. my piston crown has shown no wear from the stop... and i have used it at least 50+ times on a new gila kit..
rope!
Rope......Unless you have a chain wrench. It works awesome on the flywheel. Zero pressure on the piston or the crank. $8 at harbor freight. Priceless in the garage.
1/4" nylon multi braided rope has worked for me every time. I position the piston up far enough to clear the ports and stuff it in. For flywheel nuts that are high torque, I wouldn't want to stress the piston in such a concentrated spot. Aluminum is brittle and it can stress crack.
if they were all that bad for your piston i dont think Crane Cams would make them and i doubt Summit would sell them
Impact wrench no stop if you can avoid it. A stop will destroy needle piston pin bearings piston, pin connecting rod and much more if you have to crank Hard on clutch on flywheel. I use a stop only if need in a emergency
i fucking hate using rope.
piston stop FTW, easily one of the best purchases ive ever made, but yeah i'd probably prefer a rubber tip, metal on metal always bothers me a little.
I would go with the stop, just don't over torque anything, they are designed for some degree of force being applied.
I am usually tearing down bikes that have sat for decades that are rusty and corroded. Sometimes stopping the piston is not the issue, getting it unstopped is.
I tend to use rope more, but it has gotten hung up on the ports before. If you're using nylon rope melt the ends so they aren't frayed.
The piston stop I have is a PITA to thread into the hole for some reason.
Anything BUT an impact is either ghetto stupid or desparate (field repairs).
Only use rope with morini and sachs or any other enging with an angled plug
aaron you dont have a socket for that? maybe for on the go, the multi tool plug wrench- the impact is directly proportional to less time wrenching/ more time riding.
impacts are also great for stripping threads too
