Re: Restoring an old Vespa
Wynneth /
Well first off you should take the carb off and clean it. (Spray it real well with carb cleaner, make sure everything moves correctly and smoothly.) Depending on whether they drained all the fuel and oil before they stored it, you may have to clean out alot of gunk from the gearbox, carb, etc. If there was fuel in it, that's going to be the tough stuff to clean off. If it was running fine before they stored it, those are really the only major things. Aside from that you'll want to get new tires and tubes (at least tubes).
swarm and destroy
Wyn
  Restoring an old VespaTopic by: Tim Taylor Tim Taylor 05/17/01 05:13PM
  Re: Restoring an old VespaRe: Wynneth Wynneth 05/17/01 06:24PM
  Re: Restoring an old VespaRe: Miguel Miguel 05/17/01 07:20PM
  Re: Restoring an old VespaRe: Jim C. Jim C. 05/17/01 11:47PM
