shitty german engineering.. twin e50 maxi
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
the left motor does need oil to keep the tranny side crank bearing lubricated. they have two motors linked by what appears to be coupling nuts going from the right motor's flywheel to something where the clutch goes on the left motor. the flywheel on the right motor is held in place by a woodruff, and if the left motor has even a fraction more or less power, that woodruff is going to be under a ton of stress.
