Re: unseizing an engine
Russ /
Most any of these techniques will work. The most important factor is time. Soak at least 24 hours with a good product.. PB Blaster, tranny fluid both work. Remember, you want the engine to be useable when you are finished. Be methodical.. tap,tap, tap.... soak tap, tap, tap...soak. Work crank back and forth and it will unstick for you unless it is the bottom end. BE PATIENT.
WD40 is NOT a lubricant. If you are intent on unsticking the motor use the best product available.. PB, Marvel or any good penetrating oil applied liberally with a generous amount of time. Good luc and let us know the results.
