Re: Outside temperature/starting
Ron Brown /
Lane,
If your ped bogs at initial take off without an air cleaner, imagine how much restriction you must have at high rpm.
Make sure that the air cleaner housing/mounting does not cover any holes on the carb, many lawn mowers have this feature, presumably to discourage running without the air cleaner.
Keep in mind that your ped carb, unlike your vette, has no mechanism for squirting about a quart of gas into the intake when you nail it. Most slide type carburetors will give you best accelleration if you roll on the throttle as the revs increase. Think about air flowing past the needle jet and it will all become clear.
The CV carb was designed to resolve this problem by controlling the throttle slide with manifold vacuum, while allowing the rider to pin the throttle so he could feel macho. :-)
Ron
  Outside temperature/startingTopic by: Rick Rick 05/15/01 12:57AM
  Re: Outside temperature/startingRe: Chris Robertson Chris Robertson 05/15/01 10:23AM
  Re: Outside temperature/startingRe: stonnerdog stonnerdog 05/15/01 11:10AM
  Re: Outside temperature/startingRe: Ron Brown Ron Brown 05/15/01 11:33AM
  Re: Outside temperature/startingRe: Lane Lane 05/15/01 09:32PM
  Re: Outside temperature/startingRe: Ron Brown Ron Brown 05/16/01 11:25AM
  Re: Outside temperature/startingRe: Lane Lane 05/16/01 10:33PM
  Re: Outside temperature/startingRe: Ron Brown Ron Brown 05/17/01 10:52AM
  Re: Outside temperature/startingRe: Lane Lane 05/21/01 06:19PM
