Re: Outside temperature/starting
Ron Brown /
Lane,
The Idle mixture adjustment does not make a noticeable difference in accelleration or top speed. It mostly just smooths out the idle. I think they leave it out for simplicity and cost, even the idle jet is usually just a drilled hole in the carb body and not replaceable.
The main jet and needle, if you have one, control everything else.
Every vehicle I ever owned ran better in damp conditions provided the ignition did not leak and cause mis-fires. Check your mixture, I am not sure if humidity makes your mixture richer or leaner (Fred, where are you?), nut mayby you are jetted on the edge.
Also, check that your air cleaner does not get wet, causing your mixture to get too rich.
You can fix this, we have the technology.
Ron
  Outside temperature/startingTopic by: Rick Rick 05/15/01 12:57AM
  Re: Outside temperature/startingRe: Chris Robertson Chris Robertson 05/15/01 10:23AM
  Re: Outside temperature/startingRe: stonnerdog stonnerdog 05/15/01 11:10AM
  Re: Outside temperature/startingRe: Ron Brown Ron Brown 05/15/01 11:33AM
  Re: Outside temperature/startingRe: Lane Lane 05/15/01 09:32PM
  Re: Outside temperature/startingRe: Ron Brown Ron Brown 05/16/01 11:25AM
  Re: Outside temperature/startingRe: Lane Lane 05/16/01 10:33PM
  Re: Outside temperature/startingRe: Ron Brown Ron Brown 05/17/01 10:52AM
  Re: Outside temperature/startingRe: Lane Lane 05/21/01 06:19PM
