Help with my tomos
mopedsatdawn .blogspot.co.uk /
Hi all,
Went out for a ride on my 83 tomos A3 today
Its standard apart from leovince exhaust, Dellorto 14/14 with 56 jet
Havent had it that long so only do short local runs on it as unsure of how reliable it is yet.
Rode for maybe 6 miles and everything was fine then going down a large hill started to sound like it wasnt running right. I pulled over and kicked it over and it fired but really lumpy idle. left it for half an hour to cool down and when i started it again same problem.
Pushed it about 4 miles home plug was quite black cleaned out carb and still its running lumpy as hell on idle.
Any ideas??
Re: Help with my tomos
What do you mean by lumpy?
What i meant is when i kick it over it runs but stutters then dies. if i blip the throttle i can just about keep it running
Further explanation of the symptoms is necessary.
normally i would kick it over and it would run smoothly. Now when i kick it over the revs go up and down and it splutters
what else can i tell you?
You really need to explain more about how it runs. Idling poorly is not good enough. t It's like going to the doc and saying "I don't feel good in the morning".
Maybe you just are not getting enough fuel.try replacing the fuel line with new fuel line.put a new spark plug in.make sure your jet is not clogged.try all these simple things.
Maybe your jet is clogged.
Maybe your plug is fowled.
Maybe your jet fell out.
Maybe your carb came loose.
Maybe your reeds are broke.
Maybe you should be more descriptive.
Maybe you should ask in the repair forum.
I have cleaned the carb and made sure the jet is clear
I have cleaned the plug it was black but not oily will buy a new one today.
I made sure jet was tight when i cleaned the carb
It certainly was something sudden like the carb coming loose one moment im riding along fine and the next it splitters and cuts out.
I dont have reeds as its an A3
Ill do my best but pretty new to messing about with mopeds
I also posted in the repair forum but had more replys here.
Will try replacing fuel line today i do have an inline fuel filter installed which is in the right way round. should i remove this?
Just thought it would stop the carb getting clogged. Checked jet and its fine and will get a new plug today.
♣Slew Foot♣ /
double check your bulbs
tomos a3's need the head and tail/brakelights to run properly
my bullet would do the same thing
it took me a month to figure out it was a hairline split in the tailbulb
looked fine lit up but when the bike was running
the vibration would break the circuit and make it sputter
the delorto has this snorkel type tube
sometimes it gets joggled out of place
and it effects the idle and starting
it also fowls the auto choke plate btw it isnt stuck on is it?
hope i helped good luck
Thanx for you reply,
Both my headlight and taillight bulbs arn't working i just noticed!
Shall i just buy new bulbs? will that fix it?
Also i swapped out the dellorto and put on the old encarwi carb and still had the same problem.
So from this it shows its not the carb?
This light thing sounds like it could be it!
Thanx will investigate
