Can I re-use an exhaust gasket?
yes, as long as it doent have holes in it it should be fine
If it is a copper gasket, hang it with a piece of wire, heat it to cherry red with a propane torch, then dunk it in cold water. It will be pefectly clean and the copper will soften and make a better seal.
Ron
Cool... Thanks guys.
.-=Bohah=-.
Hey Ron, since you have motobecanes, do you know how to remove the copper exhaust gasket ? I've looked at it and it doesn't look like it threads in there, is it just a matter of sticking something behind it and popping it loose ? Thanks
Moby,
Yes,
Ron
