can't get tire off
no matter how hard i try i just cannot pull the tire off of the axel! it's an urban express so it has the one sided axel thingy like modern scooters. any suggestions? i got the nut off but just can't pull the wheel off. it's so frustrating
Re: can't get tire off
this isnt really the type of question a forum can help you with
the tire or the wheel? why? do you need to change the tire? you can change the tire without removing the wheel. also the brake pads might be broken and stuck, that happened on one of mine one time which i got for cheap because everybody thought it was seized since the rear wheel wouldnt rotate.
nope brakes work fine.
loosen the brakes some
