Just got a maxi sport and when I took apart the bing, I discovered that someone ribbed the main jet out of it! Wondering what ihe stock jet size is? Will a square bing jet work cause I think I have a Sachs carb somewhere.
it should be in the low 60's for a 2hp and upper 50's for a 1.5hp
different size slightly then the square bing, but i have gotten them to work on occasion.
you are probably needing somewhere in the 50's range, but i had a pinto that had a 70 in it when i got it so......buy a bunch. technically your ped should run until wide open throttle with no main jet, as long as it has the proper needle setting. so you should be able to ride just no going full throttle.
part way down the page is some data here
I COULD BE TOTALLY WRONG BUT THESE WERE THE EXACT NUMBERS ON STOCK PINTO'S
1.5=
1/12 INTAKE
72 MAIN JET
2.20 NEEDLE JET
NEEDLE 2ND NOTCH FROM TOP
2.0=
1/14 INTAKE
72 MAIN JET
2.17 NEEDLE JET
ALSO 2ND NOTCH FROM TOP
BUT NOW THAT I THINK ABOUT IT I RECALL A MAXI I HAD WITH A STOCK 64 FOR THE MAXI LUXE.....PROLLY 50'S FOR THE 1.5.HIGH 50'S
about 3 bucks shipped
Yeah, it's got the 1.5HP engine. I'm ordering a 58 and a 60 from treats along with a petcock (also stolen). The bike is also missing an air filter assy and foot rests? Seems like some sort of covers were originally on the sides.
My stock 2 hp has a 64 and it seems just right. Well everything stock except an unstuffed dmp crank.
it all depends on your carb #. Their are several bings all with different jets. here is a site where you can look up your bing carb
1/12/294
Stock on Puch Maxi and Puch Maxi Luxe 1 HP, main jet 52
1/12/300
Stock on Puch Sport MKII and Puch Newport 1 HP, main jet 48
1/12/293
Stock on Puch Maxi 1.5 HP, main jet 60
1/12/309
Stock on Puch Maxi Luxe 1.5 HP, main jet 48
1/12/321
Stock on Puch Sport MKII and Newport 1.5 HP, main jet 50
1/12/307
Stock on Puch Maxi Luxe 2 HP, main jet 58
1/12/314
Stock on Puch Sport MKII and Newport 2 HP, main jet 56
1/12/318
Stock on Puch Magnum XK and MK II 1 HP, main jet 50
1/12/317
Stock on Puch Magnum XK 1.5 HP, main jet 50
1/12/323
Stock on Puch Magnum MKII 1.5 HP, main jet 48
1/12/316
Stock on Puch Magnum XK 2 HP, main jet 64
1/12/322
Stock on Puch Magnum MKII 2 HP, main jet 60
1/14/152
Stock on Puch Maxi 2 HP, main jet 64
1/14/160
58 for the 1.5HP
64 for the 2HP
Any suggestion will help.Got a after market exhaust and air filter.Runs great for 30-40 minutes then shuts off and plug is black as midnight.HELP !!!
If you post your current setup you'll get much better answers. What exhaust, carb size, current jet?
> midnight.HELP !!!
Start your own thread .
Be specific ... all pertinent information .
What is the stock just cruising around jet for 1978 puch maxi 1.5hp.Any and all suggestions are welcome.Plug is midnight black after running for 30 minutes and shuts off.Was sitting for 25 years plus.
What's the number on the carb??
Lazer
Why are you replying to an 11 year old thread.
