hi,
i was wondering if someone own a cady moped - cause mine is loosing a lot of fuel (i think) when she run. i suppose i have to replace the part in the image (carb.jpg) also, if you want you can see a small quicktime of the situation.
patrick
hi,
patrick
You may want to check the gasket on the top of the fuel bowl. Both of the Batavus' had that problem and were both missing a gasket there - they are bone dry now.
Rob
I can see yer problem right off, yes.
The top plate is bent, missing a screw and yer gasket is probably torn.
Don't take this as gospel, but yannow...I think that's an old Gutrner carb.
And I know just where to get the parts for it, if it is.
Go to http://www.mopedjunkyard.com
Select MOTOBECANE, and scroll down and have a look at those carbs.
Damn me, but your's seems a dead ringer for model "C" of them.
They also have a page of em part-by-part
http://www.mopedjunkyard.com/gurtner.html
So, it looks like you can get the parts and all...I would call them about it.
See how much help postin a pic of the problem can be ?
-Ree
