'78 Tomos--Bad Headlight Update
Kyle Witten /
I'm still trying to localize the problem with my intermentant failure in the headlight. I have checked and cleaned the ground wire. I also cut off the switch and spliced the wires together so as to make the headlight an "always on" type. That didn't make the problem go away, so I know the switch wasn't bad. One thing I've noticed though is that headlight only dies while on the road [generally while at full throtle]. I've only had it die once while on the kickstand. Any thoughts?
Kyle
  '78 Tomos--Bad Headlight UpdateTopic by: Kyle Witten Kyle Witten 05/09/01 06:19AM
  Re: '78 Tomos--Bad Headlight UpdateRe: Ron Brown Ron Brown 05/09/01 10:24AM
  Re: '78 Tomos--Bad Headlight UpdateRe: Reeperette Reeperette 05/09/01 11:52AM
