Magnum swingarm on Maxi - opinions
Ryan /
I know, I know, it's been discussed. I've searched and read all the threads. I'm just wondering if it's worth the trouble for my new maxi build.
Basically, is there any other practical benefit other than being able to run wider tires?
Does it add significant stability or strength? (I'm 6'5", 215lbs)
Do most people run 320mm shocks or longer?
Is there a noticeable drop in height with 300mm shocks?
My magnum swingarm is currently mounted on another bike, so I would have to remove it (drop engine, etc.).
It's a different color, so I would want to paint it.
I would have to cut my fender.
Worth the trouble? Or is wider tires really the only benefit?
