I have a motor that uses a 10mm wrist pin bearing. Where can you find these?
honda?
derbi with 10mm .. pin :)
Derbi start3 Ed i was trying to save the original but it was too rough.
hmm I know where there a nice mk kit for that .. but its not forsale..
pictures please
isn't the stroke on tha engine like 37,4 or someshit..
dam I bet 10k sounds crazy on it.
I wonder if you could get these for kitting tomos a3 motors?
well i just busted a nut, how bout you guys? that's a pretty motor you got there.
yup thats the engine!.. dam
I need the shaft.. that the roll pin goes into and the start plate for the v..iii are the same. .. well same trannie parts.
This one was not quite that dirty but close. The piston was stuck but not seized and the pin was a bitch getting out. Now all I need to get her back running is the bearing. Ed what are you using to close your cases. I've been using long threaded rods through the case bolt holes and even torquing them.
That is the only way to put them together..dan imo.
nice and slow..
i high tach everything.. ..
I use bearing retainer when I need it or locitie when I think so. The real bitch is I can't time it.. to save me life.. just havn't had any time.
Funny but I found the bearing on a MA banner ad tha popped up on this thread. Divine intervention.
