I live in Louisville ky and need help in getting my 1973-6,vespa ciao running.It will start and run with the throttle wide open but only runs just above idle.Then it dies.Is there anyone in the Louisville area that know these engines.I am assuming 50:1 on fuel oil mix.compression is low it is 50 lb. Please contact me if you can help or have a suggestion. r.schwandner@insightbb.com >THANKS
