1981 Honda Express NC50 carb intake size
Adam Kollipara /
Is the carb intake hole size for a 1981 Honda Express NC50 14 mm?
Thanks.
~Adam
Re: 1981 Honda Express NC50 carb intake size
Adam Kollipara /
I need to know because I'm looking to get and aftermarket carb with a manual choke on it, and I want the original airbox to fit on it.
~Adam
Adam Kollipara /
I don't know if the pic will show up, but will something like this fit it? I don't want to buy the expensive things.
"Carburetor Carb Honda CT 50cc 70cc Moped Mini BiKe ATV":http://cgi.ebay.com/ebaymotors/Carburetor-Carb-Honda-CT-50cc-70cc-Moped-Mini-BiKe-ATV-_W0QQcmdZViewItemQQhashZitem2a05a8cd03QQitemZ180483575043QQptZMotorcyclesQ5fPartsQ5fAccessories
Basicly the stock size for the airbox is 1 inch inside diameter on the rubber collar and the carb itself is 1 inch outside diameter, so look for a carb with that measurement.
Adam Kollipara /
Thanks!
~Adam
Larry Parrish /
Adam_1295,
Did that carb work for you back in August 2010? I'm looking for a carb for my 81 NC50 as well and didn't know what or if i could go with something like this too.
Thanks
Larry
Adam,
Do a research on older posts.
This problem has been solved way back in Sept 2011.
'' ...As for the intake, the following intake adapter, coupled with a Mikuni Vm16 will fit without any major modifications. (a bit of shimming here and there)
You can also keep your stock air filter box.
Garelli VIP polini 19mm shorty PHBG intake
https://www.treatland.tv/garelli-VIP-shorty-PHBG-intake-p/garelli-polini-intake-215.0280.htm....'';
A big improvement over the original carb.
Adam Kollipara /
Just started back on Moped Army today. I never got that carb, Larry Parrish. I might try that or just get an older Express carb w/ a manual choke. I'll try to find the cheapest way and if I can get it to work I'll let you know.
~Adam
I bought that cheap carb and made a short adapter to bolt it to the stock nc50 intake like others have done or you can get the $60 dollar intake at treats for a Mikuni VM20 and make that work with the cheaper carb.Not a bad carb for under 30 bucks
