derbi Revo with pedals.
Odd.. these came with the old style vario setup.. but mount to a revo frame.
Lets talk some more derbi.
Re: derbi Revo with pedals.
Hmm .. thee other side.
That isn't a revo crank. that looks like a regular flat reed engine
Looks like it came off a Derbi Box those had the Start 3 with pedals like that. Whats the rear pulley look like?
Forgot to mention same frame as a Revo but different plastics. Some of the Box's had those cool 3 blades wheels.
Dan,
Just like the .. old flatreed engine setup.
Thanks, guys.. btw :)
40mm flat reed crank..
Uses the same kits are the American variants.
Just bolts up to the revo swing arms.
Anyone make shims for the transmission? I want to keep it in drive. I have to weld the gears together on the one engine.
The cases are pretty thick these compared to the old variant cases. I'll post pictures of the insides..
what are you talking about ' keep it in drive '
Matt.
I am talking about the push/pull lever for the transmission.
Either the cranks I had in the 2 engine I got .. no good, so I had to install a metra flatreed crank.
All together..
Still want to make some shims so it can never pop out of gear.
I need to find a freeze plug the size of the .. 10mm od freeze plug seal.
Some more pictures of the .. conversion..
The start v.. had no shut off valve..
So I had to install one of the mint fresh petcocks I have for the derbis.
hmm
the startv has the 420 chain....
I had to find a 420 sprocket for the front..
