Wow ryan, I never would have thought to put another mounting point right on the rear axle. good idea. I used a pretty beefy piece of steel to get it connected to one of the original mount points. but through the axle with a longer bolt seems like a good idea.
Can I see some closer pictures of those BMX pegs. I think I understand how you said you fashioned that but I want to see closer.
Also, what kind of forks are you running? Any way to swap a disc brake front end and better forks onto this thing on the cheap.
Last question, what kind of tires are you running?
