exhaust port puch e50 vs. za50
question... I have a magnum with a za50 motor.. bidding on a boss pipe listed to fit an e50. does anyone know if the header for the exhaust is the same / combatable? I am not worried about it fitting to the frame, just the za50 vs e50 header..
thanks in advance !
Re: exhaust port puch e50 vs. za50
e50/za50 isnt the difference its you have a magnum, which has a angled exhaust port so a boss pipe wont just bolt up.
Chris Doubler /
Lemme see if I understand. If I have a Maxi with a za50 on it I could put a boss on it? But if I had a magnum i could not due to the angled exhaust.
correct.
Chris Doubler /
thank you for your prompt answer M.A. (more specifically you michael)
Blah blah blah..e50 or za50 don't matter..it's the cylinder..a magnum cylinder has the angled exhaust..
