a35 airsal kit on a55
is that ok? i have an a35 exhaust aswell. i just like the reed intake better. will it bolt right on ?
Re: a35 airsal kit on a55
you might have to open the kit to match the case
LanceCampeau.com /
I spoke to Ike of Ike' Bikes on the phone last summer about this very subject and he said its a simple bolt on... works well without case matching (unless you really want to max out the kit's potential...) here is a link discussing...
http://www.mopedriders.org/viewtopic.php?t=9943&view=previous
John Joedicke /
Bolt it on. No problems, you will need a off set intake for the reed box though and a better air filter setup.
velvetunderground /
dude, the transfers are super small on that kit... a55 has huge transfers... get an alukit over the airsal if your going to do that.
ok well if i go for the alukit, and a tecnigas exhaust, which carb do you recommend?
oh also, one last thing, does the alu kit come with all the studs for the intake and exhaust?
Velvetunderground /
Get a weakens intake and a minkuni 20vm
Rob @t ATTN! Burrito /
umm, the a35 alukit i got has tiny transfers.
They are still bigger then Airsals. ^
i looked into it and i think im going to go with the a55, just because i have a better exhaust for it.
does anyone make a intake for the a55?
im going to get the kit from treats.
also i plan on keeping it oil injected, is that ok with the bigger cc's ?
also about the carbs, what is the difference between say a 2mm and a 15 mm, its it the OD of where it connects with the intake manifold?
edit, i men 20mm and 15mm
