Re: Puch 12 volt light coil
Simon Picard /
No no, The bare wires are the ground screw them on the case with the coil.
The green and yellow are positives.... The difference is the amperage that each wire can give....
Mount your coil, with the ground connected to the case, try each wire with a light bulb at idle , or 2000rpm, and you'll see one is more power ful than the other.
Usually the weak one to the tail light ( and horn, acesories ) and the powerfull one goes to the headlight.
En resumé, green and yellow 12v one with more amperage than the other one
. bare one is ground.
