Best air filter for the sha carb
I have a maxi with the twisted out intake for the sha carb. I also got the "k&n" mesh air filter. That filter is restricting my air too much. I've downjetted and still itbogs out at like 25 mph. But when I take thefilter off I'm doing atleast 35. I was jw if anyone else is having an issue with that setup? And which air filter you guys would suggest is the best one for the sha.
Re: Best air filter for the sha carb
Vlado vlado /
Benji at www.treatland.tv sells nice free flow air filters for SHA
Whaat? The metal mesh filters barrrely restrict air at all.
try again
ᴛᴇʀʀʏ ᴅᴇᴀɴ /
the stock sha filter works great
last two are right just jet proper
Well it runs awsome without a filter but with the metal mesh on it bogs out at like half throttle. I've already down jetted and I don't wanna be too lean. Originally had a 67 in it and put each in down to a 64 and all three sizes worked awsome that first day. Then the next day it just would 4 stroke at 25.
Tri-ped Dave O.D.B. /
The metal mesh filter is 4 layers of mesh. Take a needle nose and peel off two layers...voila!
