Re: Bad Headlight--'78 Tomos
Chris Robertson /
The worst problems are the ones that are intermittent!
Typically, a problem like you describe is caused by a bad ground. Look for wire that are bolted to the frame around the ped. Unbolt them, clean the contacts, and rebolt.
If this doesn't work, get back to us.
Chris.
  Bad Headlight--'78 TomosTopic by: Kyle Witten Kyle Witten 05/03/01 11:04PM
  Re: Bad Headlight--'78 TomosRe: Doug D. Doug D. 05/04/01 12:02AM
  Re: Bad Headlight--'78 TomosRe: Chris Robertson Chris Robertson 05/04/01 01:08AM
  Re: Bad Headlight--'78 TomosRe: Reeperette Reeperette 05/04/01 03:07AM
  Re: Bad Headlight--'78 TomosRe: Kasidy Manhart Kasidy Manhart 09/10/01 03:00PM
  Re: Bad Headlight--'78 TomosRe: Scott Scott 05/04/01 01:01PM
