puch magnum running but bogging out
Just got a hold of a Puch magnum xk it starts and runs fine but bogs out with throttle. Any one have any suggestions. I am mechanically inclined but am a newbie to peds.
Re: puch magnum running but bogging out
Gnihton orez /
Clean the carb and make sure the banjo filter is clean too. Use carb cleaner. Take the float out and clean the rubber tip on the float bowl valve. Make sure your float is working and is not full of fuel.
Check for air leaks.
Check your jetting.
Thanks I'll try that out and post how it works out.
Have you checked the exhaust pull it and see if the exhaust port is clean also do what deezy told me and burn your muffler to clean the carbon out of it
are you running it without an airbox??
No airbox
No airbox
Tri-ped Dave O.D.B. /
Stock jet is designed for airbox, remove the airbox without upjetting 4-6 numbers, and it will bog with throttle
any other possibilities? I'm in a very similar situation. Like, the same situation.
How do I clean/burn out the exhaust?
♣Slew Foot♣ /
okay keep it simple
first check your horn wiring
if it was bypassed it could just be grounding
second if it has a bing the choke off position is up
if it bogs right away with any throttle dollars to doughnuts
its an electrical drain or an air mix issue
my puch runs weird on the summer blend of gas
i need a super hot plug using a 5 hs normal is a 7 hs
double check the carb to see if the choke gate
is attached to the pull stem
puchs like the cold no choke should be needed unless below 30 degrees
below -10 you may need the tickle valve
ps check the spring on the tickle valve it could be letting it flood
good luck i hope i helped
Thanks I'll check those things out
tickle valve? thats the primer right?
hahahaha
.really tho, wtf does that mean
shiny it is right now. I used a dremel and was VERY carefull when removing the carbon from the port though.
