Re: Carb problems, please help!
Ron Brown /
Nick,
You say you were adding oil to the tank. Is this the gas tank, as in premix, or the oil tank.
If you were adding oil to the fuel tank, this is wrong. You should allways mix the fuel in a separate container and shake it up.
Disconnect the fuel line at the carb and make sure fuel flows freely. If it does, drain the tank and try new fuel mix.
If not, remove the petcock and clean it.
Ron
  Carb problems, please help!Topic by: Nicolas Anbeek Nicolas Anbeek 05/03/01 01:14PM
  Re: Carb problems, please help!Re: SteelToad SteelToad 05/03/01 01:19PM
  Re: Carb problems, please help!Re: Ron Brown Ron Brown 05/03/01 01:22PM
  Re: Carb problems, please help!Re: Brandon Edge Brandon Edge 05/03/01 05:22PM
  Re: Carb problems, please help!Re: Ron Brown Ron Brown 05/03/01 06:44PM
  Re: Carb problems, please help!Re: Nicolas Anbeek Nicolas Anbeek 05/03/01 01:26PM
  Re: Carb problems, please help!Re: Nicolas Anbeek Nicolas Anbeek 05/03/01 01:28PM
  Re: Carb problems, please help!Re: Ron Brown Ron Brown 05/03/01 01:55PM
  Re: Carb problems, please help!Re: Nick Nick 05/03/01 02:28PM
  Re: Carb problems, please help!Re: boombatz boombatz 05/03/01 03:18PM
  Re: Carb problems, please help!Re: daveb daveb 05/03/01 06:06PM
  Re: Carb problems, please help!Re: Nicolas Anbeek Nicolas Anbeek 05/03/01 02:46PM
  Re: Carb problems, please help!Re: tim tim 05/03/01 07:32PM
  Re: Carb problems, please help!Re: Nicolas Anbeek Nicolas Anbeek 05/03/01 08:20PM
  Re: Carb problems, please help!Re: Fred Fred 05/04/01 12:22AM
  Re: Carb problems, please help!Re: Ron Brown Ron Brown 05/04/01 10:24AM
  Re: Carb problems, please help!Re: Nicolas Anbeek Nicolas Anbeek 05/04/01 04:18PM
  Re: Carb problems, please help!Re: Ron Brown Ron Brown 05/04/01 04:50PM
  Re: Carb problems, please help!Re: Nicolas Anbeek Nicolas Anbeek 05/04/01 11:35PM
  Re: Carb problems, please help!Re: Nicolas Anbeek Nicolas Anbeek 05/06/01 05:16PM
