Carb problems, please help!
Nicolas Anbeek /
Hi everybody, and thanks for reading this. Please bear with me as I'm new to engines and learning as I go, but still quite ignorant.
I have a 1974 Batavus Bronco (dutch). The other day, I think while adding oil to the tank I think I got some shit in there somehow. The moped stopped running, with symptoms of fuel system problems - i.e. it would run for twenty feet, then stall. Then I'd wait, and it would run again a bit, and stall.
So... I took the carburetor off, and cleaned it all out. I sprayed every orifice with carb cleaner and even soaked it over night. Then I rinsed everything out with gasoline, and put it all back together.
Now, the problem seems to be a BIT better, but it's still messed up somehow. I can keep it running if I play with the gas and choke, but it keeps trying to die on me. It also lurches and stuff.... revving the gas-grip doesn't let me GO like before, just moves it a bit, then slows down, etc. However, if I run the bike on the center-stand, it goes no problem... I can spin the wheel indefinitely without it stalling.
(Sorry if I suck at describing this).
Can anybody provide ANY clues as to what my problem is? I'm quite sure I put the carburetor back together properly, yet I'm sure it's a carb problem. The ignition is fine, there is a good spark (it starts with two different spark plugs), etc.
Any advice?
Thanks in advance!
Nick
  Carb problems, please help!Topic by: Nicolas Anbeek Nicolas Anbeek 05/03/01 01:14PM
  Re: Carb problems, please help!Re: SteelToad SteelToad 05/03/01 01:19PM
  Re: Carb problems, please help!Re: Ron Brown Ron Brown 05/03/01 01:22PM
  Re: Carb problems, please help!Re: Brandon Edge Brandon Edge 05/03/01 05:22PM
  Re: Carb problems, please help!Re: Ron Brown Ron Brown 05/03/01 06:44PM
  Re: Carb problems, please help!Re: Nicolas Anbeek Nicolas Anbeek 05/03/01 01:26PM
  Re: Carb problems, please help!Re: Nicolas Anbeek Nicolas Anbeek 05/03/01 01:28PM
  Re: Carb problems, please help!Re: Ron Brown Ron Brown 05/03/01 01:55PM
  Re: Carb problems, please help!Re: Nick Nick 05/03/01 02:28PM
  Re: Carb problems, please help!Re: boombatz boombatz 05/03/01 03:18PM
  Re: Carb problems, please help!Re: daveb daveb 05/03/01 06:06PM
  Re: Carb problems, please help!Re: Nicolas Anbeek Nicolas Anbeek 05/03/01 02:46PM
  Re: Carb problems, please help!Re: tim tim 05/03/01 07:32PM
  Re: Carb problems, please help!Re: Nicolas Anbeek Nicolas Anbeek 05/03/01 08:20PM
  Re: Carb problems, please help!Re: Fred Fred 05/04/01 12:22AM
  Re: Carb problems, please help!Re: Ron Brown Ron Brown 05/04/01 10:24AM
  Re: Carb problems, please help!Re: Nicolas Anbeek Nicolas Anbeek 05/04/01 04:18PM
  Re: Carb problems, please help!Re: Ron Brown Ron Brown 05/04/01 04:50PM
  Re: Carb problems, please help!Re: Nicolas Anbeek Nicolas Anbeek 05/04/01 11:35PM
  Re: Carb problems, please help!Re: Nicolas Anbeek Nicolas Anbeek 05/06/01 05:16PM
