Re: front wheel loose???
Matt /
sounds like your front wheel bearings are shot, take the wheel off and check them, they should stay together and no rust or grime in there. if you can find any other bearings just replace them. if you cant find another set of bearings just go to your local car shop(autozone or whatever) and pick up some waterproof grease and grease up your bearings really good and then put the wheel back on, that would probly give you about a month, maybe more untill you can find some new ones or a new wheel.
  front wheel loose???Topic by: spartovi spartovi 05/03/01 03:56AM
  Re: front wheel loose???Re: daveb daveb 05/03/01 10:12AM
  Re: front wheel loose???Re: Ron Brown Ron Brown 05/03/01 11:07AM
  Re: front wheel loose???Re: Matt Matt 05/03/01 11:04AM
