I've just about had it with my ped...it's a 1975 motobecane mobylette, and needed a new piston, sounds easy enough right ? Well, the wrist pin is a VERY tight fit, so tight that it is impossible to push it through with your fingers. I have talked to several 2 stroke mechanics, even brought it in to a shop, and they've all said that they've never seen a pin that was such a tight fit. They all say it should go in pretty easy. So I made a homemade pin pusher, I've attached a picture of what it kinda looks like, and it works pretty well, but my problem is keeping the pin properly lined up with the connecting rod bearing when I use this tool. I can't see if it's lined up correctly when I use this tool because it blocks my view, so I have to line it up and then set up the tool and have someone hold the piston, but it's almost impossible to keep it steady while I'm tightening the nut on the bolt to push the pin through. If it moves the slightest bit, it's off line, and I end up wrecking the rod bearing if I keep going. Is there any way around this ? I'm reluctant to take it into a shop just yet because if the mechanic has as much trouble with it as I've had, it'll cost me an arm and a leg, probably more than I got the ped for. Is it just a matter of keeping the piston steadier when I'm pushing the pin through ? Please help me out, I love my ped but she's really pissin me off right now. Thanks.
