i got this 80 ss . The dellerto carb won't pickup fuel. so i tried another one ,nogo.but if i squirt the gas in ,it will fire. i don't feel like squirting gas in going down the road.Can any one help with this prob. Appreciated Dan
Garelli carb won't pic up fuel
Re: Garelli carb won't pic up fuel
start w/ the fuel line. work your way down. is the fuel actually going into the carburetor? is the petcock working properly? is the tank rusty? you might need an inline fuel filter. if no fuel is getting into your carburetor, that's the problem.
also dissasemble and clean the carburetor while you're at it.
the bowl is filled with gas.i check the needle its working. does the same when ichange carbs. im going to check the compression and the manifold nexts.never had one of these .im into Puch . Thanz Dan
Is your manifold clogged?
daveb
Look for the possibility of a leak in the lower end of your engine. 2 strokes use the vacuum created in the lower end when the piston goes up to draw air through the carburator. If the crank seals are shot the engine won't suck, and that sucks.
Dan,
Check for plugged exhaust. No gozintas = no gozoutas.
Also, are you absolutely sure that your "new" carb is good?
Ron
where are you squirting gas in to make it run? if it runs fine after you squirt gas in, then the problem is before that point, right? run a step-by-step diagnostic of everything between your gas tank and that point. then do it again.
