how much do magnums weigh?
ok was told my pinto weighs 75-80 pounds and can get that out of the basement with ease ! how much do magnums weigh, in the event i got one? Thanks !
Re: how much do magnums weigh?
a lot more.
Cold Trailer GARzan Justin /
Heavy as shit. When I lift mine into a truck, then lift a Maxi, it's a huge, noticeable difference. BUT, it also makes a difference when you're riding it, and it's mostly for the better. I don't know if your Pinto is 75-80lbs. I'm pretty sure a Maxi has a dry weight of around 95lbs, and a stock Mag is around 110 pounds. But I could be wrong.
i can lift my pinto's and maxi's
id not even try and pick up my magnum with hydro forks.
Looks like i would need a buddy over to help with it when i wanna ride lol
fucking heavy. even the frame is incredibly heavy just by itself. weighs way more than my rigid freespirit frame.
The UPS magnum mkII with 5 stars WEIGHTs 136.3 Pounds,MagnumII WEIGHTs 128.6 Pounds.
Yeah evan, call your boyfriend over so he can help you tote your gay bike around. Good idea!
† CH∆D † /
Minimag? EBRs Polini 21mmcarb Gazelles. Im thinking itd be similar weight as a stock magnum.
